Activity › Forums › Storage & Archiving › RAID Name Change
  • RAID Name Change
    Posted by Stephen Marshall on March 24, 2011 at 9:55 am
    Hi everyone,
    I need some help with a very strange issue.
    I use SANmp to connect to two raid arrays, RAID A and RAID B. Yesterday when I mounted RAID A, none of the file paths were correct – Final Cut was acting as though it wasn’t there etc etc.
    Now in Finder it still says the array is called RAID A, the normal file path would be
    /Volumes/RAID A/xxxxx/xxxx
    However they are now:
    /Volumes/RAID A 1/xxxxx/xxx
    Why has a “1” suddenly been added to the name? I repeat, it doesn’t look like this in the Finder window, or the “Get Info” window.
    Any help or suggestions you guys have would be great.
    Bob Zelin replied 15 years, 6 months ago 3 Members · 3 Replies
