Activity Forums Apple Final Cut Pro Legacy Raid for SD/HD and FCP compatible
  • Raid for SD/HD and FCP compatible
    Posted by Lili Chin on June 16, 2008 at 6:32 am
    Hello,
    I am looking to get a raid for my editing workflow. The way that I would like to use the SATA/ Raid (I assume I can do this) is to do the following:
    *I do not need my raid to be portable*
    a) Have a fast processing speed so that I can use HDV and SD on my G5 and swap out with my mac pro if possible via firewire 400/800
    b) be able to hotswap drives so that I can just ARCHIVE a full project with it’s media on 1 drive, pull it out when it’s done and put the drive in a drawer for safe keeping with all the media on that drive. and then put in a fresh drive when I’m ready to move on. I want to keep all my media files online and i want to have them sorted by project per drive. pulling a drive out when a project is done and replacing it with fresh avaialbe storage space.
    c) I could have it mirrored, but that would be excessive, I think.
    Can you recommend a good RAID that can do this? I’ve found the following:
    G-Tech
    https://www.g-technology.com/Products/G-SPEED-eS.cfm
    Fibrenetix
    https://www.fibrenetix.com/files/Literature_2005/FX-605-FW_1205.pdf
    thanks
    lili
    Shane Ross replied 18 years, 3 months ago 2 Members · 1 Reply
