Activity Forums Storage & Archiving RAID 0 Stripe Disappeared but the two RAID 5 slices still available…
  • RAID 0 Stripe Disappeared but the two RAID 5 slices still available…
    Posted by Jonathan Briggs on April 11, 2011 at 5:09 pm
    Hey Guys
    First of all I would like to say that the below configuration I’m about to outline is nothing to do with me and I had no say in the set up – I’m working in a small post facility and unfortunately inherited it! So yes – I know its a crazy set up but its what was here when I arrived.
    Right – basically I have a 16Tb (16 x 1Tb drives) SATA RAID which was split into two LUNS. Each LUN was configured into a RAID 5. These two RAID 5 configurations were then SOFTWARE striped into a RAID 0 config and connected to a server using SCSI.
    This set up was then split into several partitions/share points and for the last 18 months 4 edit suites have been sharing this set up over 10gig ethernet using Mac OSX Server Snow Leopard.
    Basically the other day this video server went down and upon restarting the server the Striped RAID 0 was no longer available and would not mount.
    In disk utility on the server the two separate RAID 5 slices show up as 6.4 Tb separate drives but the computer will no longer see them as a single stripe and thus none of the data can be read.
    Is there anyway to recover the Stripe without losing any/all of the data??? Is it possible to rebuild the raid with out data loss?
    Any answer would be greatly appreciated as at the moment we have many very pressing projects that are urgently required to be recovered, and getting them back from the back up set will be very time consuming and slow.
    Many Thanks in Advance
    JB
    Andrew Richards replied 15 years, 5 months ago 2 Members · 1 Reply
  • Andrew Richards
    April 18, 2011 at 1:45 pm
    Sounds like maybe the soft RAID set got corrupted. Have you tried Disk Warrior on it? I’m not at all sure if DW can repair soft RAIDs, but it is worth a shot. In all likelihood though, the RAID 0 is toast and the data is lost.
    Best,
    Andy
