Activity Forums Apple Final Cut Pro Legacy Rafael and Shane Follow up on codec not found.
  • Jeremy Garchow
    December 8, 2008 at 10:29 pm
    Did you try any of the suggestions such as changing your timeline or renders to ProRes yet?
  • Greg Ball
    December 9, 2008 at 4:31 am
    My timeline and renders were already in Pro res
  • Jeremy Garchow
    December 9, 2008 at 4:37 am
    Okay, so everything is in ProRes and you can’t export a movie?
    Is that where we are currently?
  • Greg Ball
    December 9, 2008 at 4:03 pm
    I can’t export by reference. I’ve exported the quicktime movie, but it just doesn’t look great on DVD. Lots of pixelation on people’s glasses and some movement issues (blurring stuttering) on slow pans and tilts.
  • Jeremy Garchow
    December 9, 2008 at 4:28 pm
    OK. Have you tried deleting all of your render files and rerendering?
    This is still currently your HD timeline, correct?
    Jeremy
  • Greg Ball
    December 9, 2008 at 5:48 pm
    No I haven’t done that. Can you tell me how to un-render all of the files? Can I crate a new sequence to do that so I don’t disturb the current one?
  • Jeremy Garchow
    December 9, 2008 at 6:33 pm
    [Greg Ball] “Can I crate a new sequence to do that so I don’t disturb the current one?”
    SUre, you can duplicate it. Then in the duplicate, you can select all then hit control-b twice. That will shake loose render files, but not delete them. It’s best to delete them but if you don’t want to, I understand.
    Jeremy
  • Greg Ball
    December 9, 2008 at 9:07 pm
    Okay I’m working on that now. Creating a new sequence Pro res 422. Then what do you think I should do?
    1. Drag that sequence to a new SD timeline?
    2. Export the re-rendered sequence by reference to compressor?
  • Jeremy Garchow
    December 9, 2008 at 9:15 pm
    [Greg Ball] “Then what do you think I should do? “
    https://forums.creativecow.net/readpost/8/1014320
Page 2 of 2
