Rafael and Shane Follow up on codec not found.
Hi Fellas. Thanks for your patience here. it turns out It that there multiple still images which are the culprit. However they are ALL in a RGB color space as you suggested Shane. So I’m not sure what the problem is. All of these images play fine and look great in my EX1 sequence
Rafael and others have walked me through dragging my EX1 sequence in a SD timeline. I’ve learned that Copying and pasting the EX1 time line into a new SD sequence leaves all of the still images (of which there are many) too large and distorted in the SD timeline.
Is there a way to fix this the images so I don’t have to create new moves on each one again? I’d like to just drag the the EX1 sequence to an SD sequence and render.
As I said before, I get to abut 13% render completed before I get the codec not found message. That corresponds with the first still image. Thanks for your help here.
Greg
