Activity Forums Maxon Cinema 4D Radial/Circular Wipe.
  • Radial/Circular Wipe.
    Posted by Amit Parekh on April 6, 2013 at 9:24 pm
    Hey. Basically, I have a circle spline extruded. I want it to appear like a clock wipe, starting at the top and ending at the same pos. It’s basically what the “radial wipe” effect does in AAE, but in C4D. Or is it not possible?
    Ak.
    Amit Parekh replied 13 years, 5 months ago 3 Members · 3 Replies
  • Brian Jones
    April 7, 2013 at 1:12 am
    are you looking for a texture effect or do you want the extrude itself to ‘wipe’?
  • Adam Trachtenberg
    April 7, 2013 at 2:25 am
    Instead of using the extrusion, use a cylinder primitive. It has a built-in slice function that can be animated.
  • Amit Parekh
    April 7, 2013 at 11:17 am
    Okay. Brilliant. Thank you.
