Activity Forums DaVinci Resolve R8 with DeckLink HD Extreme 3D and Kona3 in same system?
  • R8 with DeckLink HD Extreme 3D and Kona3 in same system?
    Posted by John Pilgrim on August 30, 2011 at 10:34 pm
    I’m transitioning to Resolve 8 from Color. I’ve been running a Kona3 with FCS3 and purchased a DeckLink HD Extreme 3D for Resolve.
    I’d like to keep the Kona3 in the system for legacy compatibility.
    Does anyone have any experience running a system with both a DeckLink HD Extreme 3D and a Kona3 installed?
    Obviously the Kona won’t output from R8, that’s fine. I’m interested in stability, driver conflicts, etc.
    John
    Margus Voll replied 15 years ago 7 Members · 7 Replies
  • 7 Replies
  • Charles Haine
    August 30, 2011 at 11:18 pm
    In my experience the blackmagic and kona drivers conflict with each other and you can’t get image out of either from any application (let alone Da Vinci) with drivers installed for both.
    That might have changed recently, but it’s an issue I’ve had in the past.
    Charles Haine
    Colorist, Professor
    ColorCorrection.Com
  • Paul Provost
    August 31, 2011 at 3:05 am
    slots are already at a premium as well
    you’d be better off with a legacy boot drive set up for the kona and pop that card in when you need it…
    https://www.postandbeam.tv
    grade and finish @ post + beam
    https://www.facebook.com/pages/post-beam/137967176232067
  • Margus Voll
    August 31, 2011 at 8:42 am
    or just get second mac pro. maybe older one for kona as it does not have to be as beefy as resolve machine
    Margus
    https://iconstudios.eu
  • Illya Laney
    August 31, 2011 at 9:25 am
    I’ve seen it work with a Cubix.
    twitter.com/illyalaney
    nextLAB Mobile
    SpeedGrade DI
    Resolve
    da Vinci 8:8:8 Renaissance
    Color
    Truelight
  • Jamie Allan
    August 31, 2011 at 4:01 pm
    What do you need the Kona card for?
    Should be able to use the new blackmagic card for anything you used to use the kona for
    Jamie Allan
    Post Production Consultant
    DaVinci Specialist (Linux/Mac)
    Jamie@Jigsaw24.com
    Jigsaw Systems Ltd. – IT & Broadcast specialists for the UK
    https://www.jigsaw24.com
    https://www.jigsawbroadcast.com
  • Sascha Haber
    September 2, 2011 at 9:40 am
    Smoke
    A slice of color…
    DaVinci 8.0.1 OSX 10.7
    MacPro 5.1 2×2,4 24GB
    RAID0 8TB eSata 6TB
    GTX 470 / GT 120
    Extreme 3D+ WAVE
    http://www.saschahaber.com
  • Margus Voll
    September 2, 2011 at 9:42 am
    Smoke is bad for health 🙂
    Separate machine would be cure
    Margus
