r3d pal to Prores 4444 25fps experience gamma shift after someone ran icc profiler and wacked my settings
HELP! On deadline. Big one, of course.
Experiencing gamma shift when going to h264 or flash out of pro res 4444
In the past I used fcp and cured issue with png out and then heading to other formats
I switched to adobe and never saw gamma shift out of after effects going into media encoderWhile I know this is one of those known issues that occur for different reasons at different times, it did not occur on r3d to quicktime files out before. The only difference this time was icc color profiler was run on a different monitor and we shot this one in pal and have it in pal timeline.
Workflow: After Effects – 4k r3d pal files to quicktime prores 4444 (set fo gamma autocorrect: None). This file exports out CLOSE to what it looks like in composition timeline.
From there I take it into media encoder and when I export switch to H264, it loses the gamma and goes bleached. Is there a better delivery codec I can use going out of AE that will retain color when they export to multiple formats. I want to make sure it doesn’t bleach out the minute it goes into an h264 environment, weather in their media encoder or on youtube.
Please call or help if you can asap. I desperately need this to work today.
ALL SPECS –
Model Name: Mac Pro
Model Identifier: MacPro4,1
Processor Name: Quad-Core Intel Xeon
Processor Speed: 2.26 GHz
Number Of Processors: 2
Total Number Of Cores: 8
L2 Cache (per core): 256 KB
L3 Cache (per processor): 8 MB
Memory: 6 GB
Processor Interconnect Speed: 5.86 GT/s
Boot ROM Version: MP41.0081.B08CURRENTLY USING
ATI RADEON HD 5770
also installed NVIDIA GeForce GT 120PROJECT SETTINGS
Depth 8 bits (tried 8 as well)
working space: NoneBlend colors non checked
match legacy non-checkedOutput from After FX to Quicktime pro res 4444 seems close enough to origional-ish when gamma correction in codec settings is checked off. Some gamma loss occurs when re-encoding to smaller prores file in Media Encoder. 1920 mp4 output looks somewhat close until uploaded to youtube when it loses gamma and definition
