Activity › Forums › DaVinci Resolve › R3D Files: Using Resize Info With An XML Conform
  • R3D Files: Using Resize Info With An XML Conform
    Posted by Chris Martin on March 5, 2012 at 6:56 pm
    Hey All,
    Using the resize information tab during an XML conform to 5K R3D files from a FCP project. Resolve is carrying the resize over when the offline is referenced, but I am not seeing any resize parameter changes when I go to Format.
    Example: I have a shot that has a 110% push in from FCP. Resolve is executing this push in but the input transform zoom settings still read 1.000. I would think it should read 1.100.
    So I guess my question is where is this parameter change happening? I was hoping to see the parameter change somewhere and be able to toggle on and off and be able to make further adjustments.
    What am I missing?
    Cheers, Chris
    Kevin Cannon replied 14 years, 6 months ago 2 Members · 1 Reply
  • Kevin Cannon
    March 5, 2012 at 7:04 pm
    As far as I know there is no what to see what the transform is, but you can right click on a clip thumbnail in the color page to enable or disable “use resizing info from XML” if you need to turn it off.
    The resizing effects from the XML live in the timeline (rather than in the master session, which is what shows up in the input sizing tab). It’s a little odd, I agree, but you can always turn it off and resize from the original…
    KC
    Prehistoric Digital
    PhD Grading Suite
