Activity Forums Adobe Premiere Pro R3D file import into CS4
  • R3D file import into CS4
    Posted by Beau Holland on June 16, 2010 at 8:50 pm
    I am having an issue of “Unsupported Format” in Premiere. I see the RED Sequence presets, I pick one and then try to import the files, but all of the .r3d files are grayed out. When I click and drag them from the Finder, I get the “Unsupported Format” warning. The same files import and work perfect in After Effects. All programs and plugins are up-to-date. Did I miss something?
    2 x 2.66 GHz Dual Core Intel Xeon running OSX 10.5.8
    2 GB 667 MHz DDR2 FB-DIMM
    Premiere CS4 4.2.1
    After Effects 9.0.2
    Redcode plugin 1.7
    Thanks in advance,
    Beau
    Stephen Eckelberry replied 16 years, 2 months ago 2 Members · 4 Replies
  • Stephen Eckelberry
    June 16, 2010 at 9:36 pm
    Have you downloaded the plugin from Red?
    https://www.red.com/support/release_history/15
    Stephen Eckelberry
    Currently using PP to edit “Sucker” a feature film shot using R3D footage
  • Beau Holland
    June 16, 2010 at 10:30 pm
    Yes. All updates are installed.
  • Beau Holland
    June 17, 2010 at 12:38 am
    Update… Import works fine at home on the same machine, only with 6 gigs of RAM So what could be the problem with the machine at the office?
    Beau
    June 19, 2010 at 5:29 pm
    I couldn’t figure this out either when it happened to me, so reinstalled OS X then PP & Red plugins. Drakonian, I know. OR upgrade to CS5, probably your best bet.
    Stephen Eckelberry
