Activity › Forums › DaVinci Resolve › R3D at 25fps, converted to 24fps in FCP, in xml, have error in DaVinci 9 Lite?
  • R3D at 25fps, converted to 24fps in FCP, in xml, have error in DaVinci 9 Lite?
    Posted by Isabel Arís on February 11, 2013 at 11:55 pm
    I have a problem with the DaVinci 9 Lite version. I need to correct a draft DCP (24fps) and finish in DaVinci Lite. My original Red come to 25fps. In FCP I made a xml in 24fps. At Davinci matter in Timeline, each plane is separated from another by some frames. What is happening? Thank you!
    Isabel Arís replied 13 years, 7 months ago 3 Members · 4 Replies
  • Craig Harris
    February 13, 2013 at 6:35 pm
    Your R3D files are 25fps, not 24fps.
    That is your problem.
    You should edit and grade everything in the original format (25FPS) and then convert it to a 24FPS version from the master.
    Craig
  • Joseph Owens
    February 14, 2013 at 5:07 pm
    So what you have is 25 fps media on a 24 fps timeline?
    jPo
    “I always pass on free advice — its never of any use to me” Oscar Wilde.
  • Isabel Arís
    February 15, 2013 at 12:50 am
    Thanks very much!
  • Isabel Arís
    February 15, 2013 at 1:06 am
    I wanted to finish the project in DaVinci, then do only export and not have to go through another program. But DaVinci xml not recognized correctly at 25fps.
    “Sometimes the shortest return is the longest”
