quitting render — pls help!
hi there
made a bunch of easy tweaks to a 1 minute comp with a nuber of 3d layers and a camera move moving around with andrew kramers sure target
all of a sudden what was a project that rendered fine at full rez, now i am getting error messages with like 12k x 6k image buffer error.
i dont think i added anything to screw up the comp. what could i have done
tried resetting prefs (apple, opt, shift) while starting up, secret preference with clearing cache, adding disk cache, purging all..
its weird, i dont even have a comp or layer of the size its warning about.. when i solo out layers in the master comp the error regio stops having the error. there are too many to do this all the way through the comp though
any thoughts, would be most grateful
running AE CS4 on a Macbook pro, 4gb ram
