Activity › Forums › Apple Final Cut Pro › QuickTips: Adjusting audio filters visually in FCP X
  • QuickTips: Adjusting audio filters visually in FCP X
    Posted by T. Payton on December 29, 2011 at 6:04 pm
    FCP X has a pretty fantastic feature of showing waveforms adjustments on the fly, which can easily be seen by making volume adjustments to a clip. However, it doesn’t just work for volume adjustments but for filters as well, letting you make precise adjustments before you even listen to the clip.
    The brilliance of this staggering. I’m not aware of any DAW that enables you to SEE the results of audio adjustments in real time (correct me if I am wrong). The feature lets you make adjustments in dynamics visually, as you perform them. Brilliant!
    For example, here is a voice over with obvious background noise and a noise gate applied:
    It can be clearly seen by examining the waveform that the noise is not being eliminated by the gate. So I’ll lower the threshold until and I can actually SEE the noise being eliminated:
    Here is another example of a clip with a compressor applied but with a bit to much gain which introduces peaking:
    So I enable the brick wall limiter, and adjust the threshold until the peaks are gone.
    Wow!
    T. Payton
    OneCreative, Albuquerque
    Tom Wolsky replied 14 years, 9 months ago 2 Members · 3 Replies
  • Tom Wolsky
    December 29, 2011 at 11:01 pm
    Very nice. This feature was in STP as well.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
    Coming in 2012 “Complete Training for FCPX” from Class on Demand
    “Final Cut Pro X for iMovie and Final Cut Express Users” from Focal Press
  • T. Payton
    December 29, 2011 at 11:21 pm
    I just check this and actually the waveforms in STP were computed when filters were added to the “action list”, but only after you applied a filter, not while adjusting parameters, and it was a much slower process. The waveforms in FCP X redraw while you adjust parameters.
    I just did a quick test and FCP X seems to compute the waveforms about 3x as fast as the beloved STP.
    T. Payton
  • Tom Wolsky
    December 30, 2011 at 2:47 am
    The wonders of faster processing.
    All the best,
    Tom
