Activity › Forums › Apple Final Cut Pro Legacy › **Quicktime won’t play DVCPro HD files in Mac Pro – PLEASE HELP!!!!!**
  • **Quicktime won’t play DVCPro HD files in Mac Pro – PLEASE HELP!!!!!**
    Posted by Rose Glandfield on November 19, 2007 at 5:56 pm
    Hi
    I’ve just upgraded to a Mac Pro from a G4, am editing in DVCPro HD (720P60) and have no problems working with source files in FCP 5.0.4 but cannot play the same files in Quicktime. When I attempt to play any DVCPro HD aterial in Quicktime, I get a white screen with audio only playing, anda message saying that the required component is not available and directing me to an apple webpage which does not appear to have any relevant downloads on it.
    I have the DVCProHD codec installed in the Library/Quicktime folder, so that’s not the issue. It seems that the problem may be in moving from a PowerPC based mac to an Intel based one.
    Apparently the DVCPro HD Codec created by, I believe Panasonic, to work with FCP, only works in PowerPC mode. I have 30 hours of DVCPro HD media which I am cutting with in FCP, and need to be able to export and play in Quicktime as quickly and with as little compression loss as possible.
    Any ideas as to how I can achieve this would be most gratefully received.
    Rose
    Tom Wolsky replied 18 years, 10 months ago 5 Members · 9 Replies
  • 9 Replies
  • Walter Biscardi
    November 19, 2007 at 6:02 pm
    And you’ve updated Quicktime to the latest and greatest?
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR
    The new Color Training DVD now available from the Creative Cow!
    Read my Blog!
  • Tom Wolsky
    November 19, 2007 at 6:03 pm
    That version of FCP is not compatible with an Intel-based machine. You need FCP5.1 or later.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop”
  • Sam Wells
    November 19, 2007 at 6:35 pm
    You need a newer, Universal Binary version of the Quicktime component(s) in question.. I’m surprised FCP works at all as your post implies.
    5.1.x should do the trick.
    -Sam
  • Rose Glandfield
    November 19, 2007 at 7:17 pm
    Thanks for all your responses.
    I am using Quicktime Pro (7.3)
    I have had no problems using FCP 5.0.4 on this system, but will nonetheless upgrade.
    The problem is with Quicktime, however. Sam, you say I need a “newer, Universal Binary version of the Quicktime component(s) in question”
    Where can I get such a thing from?!
  • Tom Wolsky
    November 19, 2007 at 7:20 pm
    The pro components like DVCPRO HD are available with the pro apps. You need the UB version of the pro apps to get the appropriate QuickTime components.
    Depending on the version of the OS yo might be able to revert to an earlier version of QuickTime that will work, but it may not be possible without having the correct version of FCP for that machine.
    All the best,
    Tom
  • Johnsabbath D’urzo
    November 19, 2007 at 9:08 pm
    What’s Class on Demand DVDs. Where can I get these this will help me out a lot. Do they teach FCP working with HD
  • Tom Wolsky
    November 19, 2007 at 10:23 pm
    https://www.classondemand.net/classondemand/final-cut-training/fcp6.aspx
    All the best,
    Tom
