Activity Forums Apple Final Cut Pro Legacy QuickTime with 5.1 audio to play out mac opticle port
  • QuickTime with 5.1 audio to play out mac opticle port
    Posted by Mark Linthicum on July 10, 2007 at 10:23 pm
    I need to play a movie for a screening, I am thinking I would just make a pro res QuickTime with 5.1 aac in compressor. Does anyone know if this will work and anything I might need to do. I have never made a QT with 5.1 or used the opticle port so any info would be geatly apreaciated.
    mark
    Mark Maness replied 19 years, 1 month ago 3 Members · 3 Replies
  • David Roth weiss
    July 11, 2007 at 1:08 am
    Why wouldn’t you simply create a DVD with Dolby 5.1 tracks?
    “No job is worth doing more than once…”
    David Roth Weiss
    Director/Editor/Post-production Supervisor
    David Weiss Productions, Inc.
    Los Angeles
  • Mark Linthicum
    July 11, 2007 at 2:20 am
    I have uncompredded HD I do not want to compress it and I do not want to show SD.
  • Mark Maness
    July 11, 2007 at 7:31 pm
    Connect the optical cable to an amp or stereo receiver that has an optical port. Make sure that in your System Preferences – Sound that you select your Output as Digital Out.
    It should work like a charm.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
    https://blogs.creativecow.net/waynecarey
