Activity Forums Adobe After Effects Quicktime version
  • Quicktime version
    Posted by Mstleger on July 26, 2006 at 2:02 pm
    Just wondering, is there any way to run multiple versions of quicktime on the same machine? It seems like AE 6.5 doesn’t like QT v7. I’m working with footage that is compressed with the animation codec, and I see lots of artifacts from other frames. I reverted back to QT 6.x and the problem went away.
    Mstleger replied 19 years, 9 months ago 2 Members · 4 Replies
  • Mylenium
    July 26, 2006 at 5:33 pm
    Nope, you can’t have multiple versions of QT under one OS. Since QT and its CoDecs runs as a system component every install replace the other files with the same name.
    Mylenium
    [Pour Myl
  • Mstleger
    July 26, 2006 at 6:01 pm
    That makes sense.
    I remember hearing alot about problems with QT 7 and AE. Was there ever a patch or fix available? I searched the posts, but found 100’s of unrelated quicktime problems.
  • Mylenium
    July 26, 2006 at 6:13 pm
    Actually everything after QT 7.0.3 should work fine. Apple simply overshot the line a little by forgetting all their legacy functions when implementing all that H.264 and other CoDec stuff, but problems should be fixed.
    Mylenium
    [Pour Myl
  • Mstleger
    July 26, 2006 at 7:20 pm
    cool, thanks.
