Activity Forums Apple Final Cut Pro Legacy quicktime that works on a PC
  • quicktime that works on a PC
    Posted by Tim Pearce on October 18, 2006 at 11:39 pm
    hi,
    I’m exporting minidv NTSC footage using FILE>EXPORT>QUICKTIME MOVIE
    The result is a “Final Cut Pro Movie File”. This will open using quicktime player on my mac. I want to show the project on a PC though. The PC won’t open the Final Cut Pro Movie File. I tried opening the FCP Movie File on my mac quicktime player and exporting it as a quicktime file. This second generation file can be opened by PC quicktime player, but even with the export setting set to the best, there is still huge degradation in the image. Is there any way to export a PC readable file from a FCP mac project (either in FCP itself or some other programme)? Thanks for any help!
    Tim
    Jeff Carpenter replied 19 years, 11 months ago 3 Members · 2 Replies
  • David Roth weiss
    October 18, 2006 at 11:52 pm
    Tim,
    Just add the .mov extension onto the file you originally exported from FCP, its not really a FCP movie file, just a QT without an extension, and it will play on a PC. There should be no “degradation,” however, there may well be a gamma shift that could require correction.
    DRW
  • Jeff Carpenter
    October 19, 2006 at 2:00 am
    David’s advice should work, but in the future you can avoid it by using FILE>EXPORT>QUICKTIME CONVERSION
    Same thing as what David’s saying, just without having to add the .mov yourself.
