Activity Forums Apple Final Cut Pro Legacy quicktime player question
  • quicktime player question
    Posted by Nick Avaliani on March 9, 2011 at 12:08 am
    I am exporting image sequence from qt 7. Is it pro or simple qt how do I know? I wasa told I cannot expoprt image sequence from qt if it is not pro. So is it true?
    I am concerned cause I am making tiffs for dcp and I need to have the best result possible. Thaks
    Jerry Hofmann replied 15 years, 6 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    March 9, 2011 at 2:34 pm
    If you installed the QT player 7 from the Studio disks, you have the pro version of QT 7 and it will be normally in the Utilities folder.
    Yes, you can export a still image sequence from it too. You can also export an image sequence directly from FCP using “QuickTime Conversion” in the export sub menu.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
