Activity › Forums › Adobe After Effects › Quicktime not found
  • Quicktime not found
    Posted by Paul Dashwood on January 29, 2014 at 7:09 am
    Hi There, I have read all the posts I can find but none seem to solve my problem I get this message .
    I cannot choose an output because of this
    and then get this message
    These is the versions I am using. Quicktime 10 and after effects 12
    I would so appreciate any help as I’m becoming desperate.
    Thank you so much
    Paul
    John Cuevas replied 12 years, 8 months ago 3 Members · 3 Replies
  • Doyle Lewis
    January 29, 2014 at 5:14 pm
    I actually just had the same problem two days ago. I did a full restart of my computer and then AE started recognizing QuickTime again. I had done a disk repair and cleared out a ton of temp files the day before that so I don’t know if that had anything to do with it. Have you used Mac’s disk utility recently?
    Doyle Lewis, Assistant Videographer
    thinkck.com
  • Paul Dashwood
    January 29, 2014 at 6:42 pm
    Thanks Doyle,
    2 days ago I had my mac serviced but I will have a look at clearing out old files – this is really frustrating
  • John Cuevas
    January 29, 2014 at 9:16 pm
    I believe there are some issues with the new mac os, quicktime and AE. I believe the solution is to use QT7, but you might want to check around first.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
