Activity › Forums › Apple Final Cut Pro Legacy › Quicktime NONE wont come into FCP 6.0.2
  • Quicktime NONE wont come into FCP 6.0.2
    Posted by Sean Kapleton on February 6, 2008 at 10:51 pm
    I am trying to import a quicktime movie with NONE compression into FCP 6.0.2 and it will not work – its says it cant recognize file format.
    My senior editor tells me that it should work and origianlly it was actually an SAD Same as Source avid mov which he then converted in QT pro with millions+ NONE best quality settings
    Can ayone help me figure out what the problem is? i tried restarting and doing software update but its still wont work
    thank you
    s
    Chris Borjis replied 18 years, 7 months ago 2 Members · 1 Reply
  • Chris Borjis
    February 6, 2008 at 11:19 pm
    was it “self contained” or a “reference movie?
    it has to be self contained.
    try ANIMATION codec if NONE does not work.
    It will look exactly the same and take up a little less room.
