Activity › Forums › Apple Final Cut Pro Legacy › quicktime .mov files losing sync on import
  • quicktime .mov files losing sync on import
    Posted by Jonathon Fulton on May 18, 2011 at 6:30 pm
    Hi
    I have several short (under 5min) clips that I ripped off of DVDs using DVDxDV. I created quicktimes which play just fine in Quicktime. And played fine when I created a new compilation DVD.
    When I import them into FInal Cut pro they loose sync dramatically.
    The time line is standard DV 720×480 29.97fps. The clips show up with all the same settings as the Sequence.
    Final Cut Pro 6.06 Max OS X 10.5.8 2×3.2GHz Quad Core Intel Xeon 8GB ram.
    Any ideas?
    Chris Borjis replied 15 years, 4 months ago 2 Members · 3 Replies
  • Chris Borjis
    May 18, 2011 at 6:56 pm
    is the audio 16-bit 48khz?
  • Jonathon Fulton
    May 18, 2011 at 7:20 pm
    Yes, both the sequence and the clip are 48 khz, although the sequence is 32 bit.
    Jon
  • Chris Borjis
    May 18, 2011 at 9:49 pm
    32 bit audio?
