Activity Forums Apple Final Cut Pro Legacy Quicktime interpreting anamorphic DV footage as 872.72×480
  • Quicktime interpreting anamorphic DV footage as 872.72×480
    Posted by Adam Liss on May 9, 2012 at 11:01 pm
    Over the past month or so, I noticed small black bars at the top and bottom of all the SD videos I produced. For a while, I just ignored it, but as it keeps happening (and it’s begun to happen on some of my co-workers computers), I’m realizing this might actually be a bigger problem.
    I’ve discovered that the issue is that after exporting from FCP, Quicktime interprets the video as being 872.72×480, which is due to the fact that it’s conforming it to Production aperture, rather than Clean. I have no idea where the setting for this is stored, nor why it would suddenly switch.
    Has anyone else experienced this, and have they figured out a way to fix it without manually adjusting every video?
    Rafael Amador replied 14 years, 3 months ago 2 Members · 3 Replies
  • Rafael Amador
    May 10, 2012 at 2:12 am
    FC exports everything with Production aperture.
    If that bothers you, you can change the aperture in the “Clip Properties” (Cmd-J) > Presentation.
    rafael
    http://www.nagavideo.com
  • Adam Liss
    May 10, 2012 at 2:39 am
    Up until the past month or so, It exported without any aperture selected, not sure what caused it to change…
  • Rafael Amador
    May 10, 2012 at 8:56 am
    Anyway, Aperture only affects to how QT player display the picture.
    rafael
