Activity Forums Apple Final Cut Pro Legacy QuickTime IMX50 & MXF
  • QuickTime IMX50 & MXF
    Posted by Marc Lucas on March 30, 2012 at 9:13 am
    Been asked to produce either QuickTime IMX50 (D-10/ IMX)files OR MXF files for online delivery. Do I have to get a Compressor plugin to enable a MXF file export or is the QuickTime IMX50 something I could just export out of Compressor? Also the encode profile says a 50MBPS MPeg-2 file at 50mbs GOP structure I-Picture only.
    Any help will be appreciated.
    Jeremy Garchow replied 14 years, 5 months ago 3 Members · 11 Replies
  • 11 Replies
  • Rafael Amador
    March 30, 2012 at 12:16 pm
    You can export the IMX out of FC or Compressor without need or any plugin or component.
    You should find an IMX.50 export option in QT and have an “Easy setup” for the IMX.50 in FC.
    rafael
    http://www.nagavideo.com
  • Jeremy Garchow
    March 31, 2012 at 2:49 pm
    You can also use the Sony transfer software to make MXF files.
    Jeremy
  • Marc Lucas
    March 31, 2012 at 2:59 pm
    Thanks I saw that recently on another post whilst researching. I think I’ll just export straight out of FCP and use the QuickTime conversion export function to export the IMX file. I think this will be easier and save more round tripping.
    Thanks for the replies!
  • Jeremy Garchow
    March 31, 2012 at 3:21 pm
    As long as they are cool with .mov, yeah.
  • Marc Lucas
    March 31, 2012 at 3:25 pm
    Yes they specified either the IMX or MXF formats. The IMX they wanted in a QuickTime wrapper so all is good. Still might have a go at creating an MXF file though just so I know how to do it in the future.
    thanks
  • Jeremy Garchow
    March 31, 2012 at 3:42 pm
    It’s good practice and the software is f-r-e-e.
  • Marc Lucas
    April 3, 2012 at 10:39 am
    Did the above with regards to easy setup and MPEG IMX 625/50 (50Mb/s) I also chose the size as PAL 720×576 16:9 but when I export that file and check its dimensions in Media Inspector it comes in at a 4:3 file
  • Marc Lucas
    April 3, 2012 at 11:37 am
    Can’t understand why when I select the IMX 625/50 setting in QuickTime I lose the ability to select 16:9 anamorphic?
  • Jeremy Garchow
    April 3, 2012 at 12:54 pm
    Use compressor instead of QuickTime as you can set the PAR for PAL 16:9 in the geometry tab.
    Jeremy
  • Marc Lucas
    April 3, 2012 at 1:09 pm
    I have tried that but when the file comes out it is 4:3
