Activity Forums Adobe After Effects Quicktime freezes after fx
  • Quicktime freezes after fx
    Posted by David Kenny on August 23, 2008 at 11:57 am
    I have a problem that is whenever i try to import a quicktime movie file into the composition it freezes my entire after effects (cs3).
    My comps spec is:
    Intel core 2 quad 2.4 ghz
    3Gb Ram
    GeFore 9600 GT
    I suppose im looking for codecs to use with after effects to prevent this from happening, when i go to play quicktime movies when not in after fx it works perfectly, just after fx doesn’t like quicktime for some reason.
    Hope you can help
    Kenny
    David Kenny replied 17 years, 11 months ago 58,846 Members · 1 Reply
  • David Kenny
    August 25, 2008 at 4:31 pm
    Thanks for responding the codec is one of the ones listed HD one but if i want to keep the quality what codec do you suppose converting it too ? to keep quality
    I have tried avi in past but the videos are set keyable so are already transparent when i want to use in project whereas if i convert to .avi i loose quality when keying out the black.
    So what quicktime codec does after effects actually like?
    Kenny
