Activity Forums Adobe After Effects Quicktime Frame size limit/restriction
  • Quicktime Frame size limit/restriction
    Posted by Kazumi Hatori on July 30, 2010 at 8:43 am
    I usually work with video in high resolution, i.e. 3 1024×768 output to three projectors, that’s 3072×768.
    What I did is have the animation done, compressed to Quicktime H264 and it works fine.
    Once I upgraded to CS5, either AE or encoder don’t allow me to let the h264 quicktime to be larger than 2k resolution. Why is that happening??
    And I would also like to know what format/codec are usually used in outputing 3K up video to be played in computer, thanks!
    Kazumi Hatori replied 16 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
