Activity › Forums › Adobe After Effects › Quicktime Format H.264 Codec export issues
  • Quicktime Format H.264 Codec export issues
    Posted by Eric Bradberry on January 9, 2013 at 7:49 pm
    I need some help with an export issue. I need to export a 1920×1080 COMP from after effects with an H.264 codec. Everytime it hangs up and never recovers. Is there any documentation about frame size stipulations for H.264 codecs?
    Any help would be greatly appreciated.
    Eric Bradberry
    Supervising Editor @ Formation Advertising
    HP Z800
    Intel Xeon CPU X5680@3.3GHz Dual
    16 GB memory
    Windows 7
    Todd Kopriva replied 13 years, 7 months ago 4 Members · 5 Replies
  • Roland R. kahlenberg
    January 9, 2013 at 11:36 pm
    1080 comps should be fine for rendering to the H264 CODEC. It is after all the de facto CODEC for Bluray Discs. Try rendering to another CODEC to ascertain if it’s a CODEC or comp/layer/effect issue.
    Lastly, when rendering to the H264 CODEC, it is ideal to use Adobe Media Encoder (AME) instead of AE. AME allows for 2-pass VBR and renders in the background if AE is running concurrently.
    To render via AME, simply import an AEP instead of a movie. Then select the appropriate Composition for rendering.
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects ACE/ACI (version 7)
  • Tom Daigon
    January 10, 2013 at 12:39 am
    Eric, I have the very same issue on my Z820. I spent 3 days trouble shooting with someone who really know computers and Adobe software.
    Even reinstalled Win 7 and then tested the export process before I added another piece of software to the system. MPEG Streamclip had the same problem. So I gave up on Quicktime H.264 and stared doing MP4 H.264.
    Something is up with QT on PCs that caused thing hang problem every time.
    Tom Daigon
    PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    https://www.youtube.com/watch?v=DxPrG3WUyz8
    (Best viewed at 1080P and full screen)
    HP Z820 Dual 2687
    64GB ram
    Dulce DQg2 16TB raid
    January 10, 2013 at 12:43 am
    QT’s H264 is flaky. Select the H.264 format instead.
    HTH
    RoRK
  • Eric Bradberry
    January 11, 2013 at 3:55 pm
    I can easily export in H.264 package (mp4) but not a .mov with an H.264 codec in AE or AME. it will not work.
    Eric Bradberry
    HP Z800
    16 GB memory
    Windows 7
  • Todd Kopriva
    February 12, 2013 at 3:44 am
    See this, which I updated with information about hyperthreading and Apple’s H.264 encoder:
    “troubleshooting QuickTime errors with After Effects”
    After Effects team blog
