Activity Forums VEGAS Pro Quicktime files not importing correctly
  • Quicktime files not importing correctly
    Posted by James Strecker on February 3, 2014 at 3:22 am
    Hi, everyone. I apologize if this is a repost of a problem that has already been dealt with in the past, but I cannot seem to find a solution online anywhere.
    The problem I am having is that any time I try to bring in any type of Quicktime file into my timeline, it imports the audio but the video is just blackness. There is a video aspect that appears on the timeline, so it’s not like it’s only importing audio…in a way. There is video along with it, it is just nothing but black. This goes for .mov, .mp4, and any other Quicktime file type.
    The strangest part is that I can usually link this to a Quicktime update but there has not been one that coincides with this issue beginning. I have video from my iPhone that I need to work with, as well as various effects shots that I rendered as Avid DNxHD codec .mov files.
    Any help would be greatly appreciated and I can supply more information if needed.
    Thank you!
    James Strecker
    JTS Entertainment
    https://www.youtube.com/JTSEntertainment
    Ronald Reed replied 11 years, 11 months ago 8 Members · 28 Replies
  • 28 Replies
  • James Strecker
    February 3, 2014 at 3:27 am
    P.S. This only started happening within the last few days. I have always been able to import and work with these file types in the past. I don’t know what changed or how to fix it.
    James Strecker
    JTS Entertainment
  • Steve Rhoden
    February 3, 2014 at 11:50 am
    Any kind of update at all done in those last couple of days?
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-461-9019
  • John Rofrano
    February 3, 2014 at 1:08 pm
    Have their been any Windows updates? You never know what Microsoft is changing that breaks other programs. I turned Windows updates off and I apply them all once a month after my full monthly backup. Open the files in the QuickTime player and press Ctrl+I to bring up the Inspector and see what codec they use and be sure it is a codec you have installed although if they come from your iPhone they should be AVC/H.264.
    You didn’t mention what version of Vegas Pro you have but older versions need an older version of QuickTime.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Scott Simpson
    February 3, 2014 at 3:27 pm
    I updated Itunes (Win64) a few days ago and it broke Quicktime and DNxHD entirely.
    Had to uninstall all the Apple software, iTunes, Quicktime, and reinstall everything including a repair install of DNxHD.
    I thought it was just me, but apparently the latest iTunes win64 update is messing up a lot of people.
    Radio guy in a TV world. Bigasssuperstar.com
  • Steve Rhoden
    February 4, 2014 at 3:56 am
    When you have an editing system, its a bad idea to do automatic updates.
    Steve Rhoden
    (Cow Leader)
    1-876-461-9019
  • Stephen Crye
    February 4, 2014 at 5:46 am
    Ditto what they said – do windows updates manually and with caution.
    See if you have a system restore point to which you can roll back.
    If you don’t have a restore point available, then review the System Restore settings, make sure it is on and set to backup files as well as config.
    Steve
    Win7 Pro X64 on Dell T7500, MultiTB SATA, 12GB RAM, nVidia Quadro 2000, Vegas 12, 11, 10, 9 DVDA 6.0 & 5.2(build 135) Sony HDR-CX550V, Panasonic GH3 with LUMIX G X VARIO 12-35mm / F2.8 ASPH, LUMIX G X VARIO 35-100mm / F2.8
  • John Rofrano
    February 4, 2014 at 12:50 pm
    I’m using the latest QuickTime 7.7.4 with the latest iTunes 11.1.4 with the latest Vegas Pro 12.0 Build 770 and I’m not having any problems. I can read and render to Avid DNxHD just fine.
    ~jr
  • Steve Rhoden
    February 9, 2014 at 11:31 am
    A conflict is going on somewhere!
    Steve Rhoden
    (Cow Leader)
    1-876-461-9019
  • Gabriel Guerrero
    February 17, 2014 at 4:08 am
    Hi John, I have Win 8 64 bit Sony Vegas pro 12 64 bit, latest Quicktime version
    I had tried all the options shown here but still when I import .mov file I only get the audio.
    no video. Please help, thanks a lot
  • John Rofrano
    February 17, 2014 at 6:43 pm
    Hi Gabriel, Open the MOV file in the QuickTime Player and press Ctrl+I to bring up the Inspector window. What does it say under Video Format? This will tell you what video codec you need to display the file correctly.
    ~jr
Page 1 of 3
