Activity Forums Apple Final Cut Pro Legacy quicktime export problem – urgent!!
  • quicktime export problem – urgent!!
    Posted by James Lee on April 20, 2006 at 5:34 am
    I am having problems trying to open my quicktime exported movie on a PC. This seems to be happening with all of the sequances that i exported AFTER upgrading to FCP 5. When I try to open it, I get a dialog stating the quicktime program does not have all the necessary components to open the file…but yet it open fine on my mac. The older exported files from FCP 4.5 is opening fine on the PC. oh, i’ve already upgrade my pc to quicktime 7.
    export —> quicktime –> use current settings
    FCP 5
    OSX Tiger
    thanks!
    J
    Tom Matthies replied 20 years, 4 months ago 3 Members · 3 Replies
  • Bret Williams
    April 20, 2006 at 5:43 am
    What codec are you exporting them as? Perhaps the PC you’re using might require such codec.
    Or perhaps you’re exporting a reference movie. Your export needs to be “self contained” if it’s leving your computer obviously.
  • James Lee
    April 20, 2006 at 6:10 am
    exporting as current settings which is
    DV/DVCPRO-NTSC
    29.97
    frame size: 720×480 NTSC DV.
    These settings are the same as before and it works fine on my PC.
  • Tom Matthies
    April 20, 2006 at 1:14 pm
    Just a shot in the dark here. If you are funning FCP 5, you are most likely running Quicktime 7. Could your PC possibly need to upgrage to a newer version of Quicktime viewer?
    Just a thought…
    Tom
