Activity Forums Adobe Premiere Pro quicktime export : “file size in gb!!
  • quicktime export : “file size in gb!!
    Posted by Baran Venkatasamy on January 28, 2010 at 5:12 am
    hi folks
    Actually am working on video capture of tutorials using camtasia.then from camtasia(camrec file) am exporting the output as avi, so that i can do better editing in premier cs4 & other work .then after my final editi is over in premier cs4 i wanna export the video as quicktime.when i export the video everytrhing works perfect except file size coming in 12 gb for an 1 hr 24 min video.
    these are the export settings i use for quicktime :
    General
    Editing mode: Desktop
    Timebase: 15.00fps
    Video Settings
    Frame size: 1024h 768v (1.0000)
    Frame rate: 15.00 frames/second
    Pixel Aspect Ratio: Square Pixels (1.0)
    Fields: No Fields (Progressive Scan)
    Audio Settings
    Sample rate: 44100 samples/second
    Default Sequence
    Total video tracks: 3
    Master track type: Stereo
    Mono tracks: 0
    Stereo tracks: 3
    5.1 tracks: 0
    Submix mono tracks: 0
    Submix stereo tracks: 0
    Submix 5.1 tracks: 6
    i couldn’t understand whats happening here.any suggestions will really help me a lot
    thanks in advance
    baran
    Baran Venkatasamy replied 16 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
