Activity Forums Adobe Encore DVD Quicktime error with Encore CS4 for Mac
  • Quicktime error with Encore CS4 for Mac
    Posted by Brian Johnson on August 11, 2010 at 10:28 pm
    Hi all,
    I’m having issues with burning DVDs with Encore that has only recently started. Hopefully someone here can help me figure out what’s happening.
    I have an Encore CS4 Mac project with a dynamically linked SD sequence from Premiere Pro. I’ve transcoded the video and am trying to burn the project to a DVD. The project file and all source media are on an external WD hard drive plugged in via USB. I’ve tried burning with my MacBook Pro’s Superdrive as well as with a Lacie external Blu-ray drive. It writes to the DVD for a while and then eventually cancels the burn itself. A window pops up that says “QuickTime system error: = -1”. I was having this problem last week and after restarting my computer a couple times I managed to get 2 DVDs that were fine after throwing 8 away that had screwed up. Now I’m burning DVDs from a different project and am getting the same error message repeatedly.
    Help!
    Daniel Ludwig replied 16 years ago 2 Members · 1 Reply
  • Daniel Ludwig
    August 22, 2010 at 1:09 pm
    Hi Brian,
    could you try to create an DVD-disc-image with encore and try to burn this to using the harddisk-utility or toast?
    what kind of media-type are you using?
    cheers
    danny
