Activity › Forums › VEGAS Pro › Quicktime error in Sony Vegas 12
  • Quicktime error in Sony Vegas 12
    Posted by Bradley Graham on January 22, 2013 at 12:17 am
    Hi there, I have been using Sony Vegas 10 for a while and I recently purchased a new computer with Windows 8, and I also upgraded to Sony Vegas 12. After installing Vegas 12 on my new system I found that all of my quicktime video clips that I used in Vegas 10 on my old computer aren’t working on my new system, it’s saying that Quicktime is not recognized or something, and it gives me a link to download it, but I already have the newest version of quicktime installed.
    I googled this and couldn’t get a clear answer so I was hoping someone here would have experience with this issue. Thanks in advance
    Paul Seraphim replied 13 years, 1 month ago 4 Members · 5 Replies
  • John Rofrano
    January 22, 2013 at 11:16 am
    [daniel fienberg] “After installing Vegas 12 on my new system I found that all of my quicktime video clips that I used in Vegas 10 on my old computer aren’t working on my new system, it’s saying that Quicktime is not recognized or something, and it gives me a link to download it, but I already have the newest version of quicktime installed.”
    What codec do the files use? QucikTime is just a container for video, it’s not a video format. You must still have the correct codecs installed in order to play the files. For example, if the QuickTime files use the Avid DNxHD codec, you will need to download and install it because it doesn’t come with the QuickTime installer.
    You can use MediaInfo to find out what codec the files use. Then install the proper codec from the manufacturer that makes it. Do not, under any circumstance, install something called a “codec pak”; just get the one codec that you need.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Mike Kujbida
    January 22, 2013 at 12:00 pm
    The newest version of QuickTime has been a problem for a lot of people. Try an older version and see if that helps.
    https://support.apple.com/downloads/#quicktime
  • Bradley Graham
    January 23, 2013 at 1:17 am
    Thanks very much for the help, installing an older version of Quicktime worked
  • Mike Kujbida
    January 23, 2013 at 2:18 am
    Glad to hear that was the solution. Happy editing!!
  • Paul Seraphim
    August 29, 2013 at 8:06 am
    which quicktime did you end up installing which older one!? please help!
