Activity Forums Apple Final Cut Pro Legacy Quicktime Error
  • Quicktime Error
    Posted by Nicholas Bierzonski on April 19, 2007 at 4:59 pm
    I was wondering if anyone has had this same issue?
    Occassionally when I export from Compressor my AIFF audio will the have the following message: “Failed: Quicktime Error -50”
    My AC3 audio file is fine. And this is what I use for the DVD.
    It seems to happen more with SD 10 Bit uncompressed video converted to MPEG2…
    NTSC DV converted to MPEG2 doesn’t seem to be a problem.
    I would say this error shows up maybe once out of every 10 encodes. It doesn’t happen enough to be a problem….but I just wondering what could cause this issue?
    I am using FCP 5.2.1 & Compressor 2.3 on a G5…
    -Nicholas Bierzonski
    Editor/DVD Author/Java Boy
    http://www.finalfocusvideo.com
    Nicholas Bierzonski replied 19 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
