Activity Forums AJA Video Systems Quicktime Error (-101) – AJA Kona causing this issue?
  • Quicktime Error (-101) – AJA Kona causing this issue?
    Posted by Jessica Mantheiy on December 20, 2012 at 4:15 pm
    Currently running 10.7.4 with an AJA Kona LHi connected and keep receiving error code (-101) when trying to play back videos using Quicktime Player X. I have read that the error could be a result of:
    1. Sound device on logic board
    2. External sound device
    3. 10.7.4 update
    Reading also is to either repair the sound device on the logic board, wait for a new driver to come out for the external sound device, or do a fresh install of Lion.
    However, has anyone ever run into the issue of a AJA Kona as the external sound device causing this issue?
    Jessica Muth
    jm*****@***il.com
    Bob Zelin replied 13 years, 4 months ago 3 Members · 2 Replies
  • Steve Modica
    December 20, 2012 at 4:56 pm
    Try this:
    Create a new account on the system and login to it. Then try. The new account will have clean preferences.
    If that works, go back to the old account and delete all the Aja prefs and try again. If it fails, you know you have a systemic problem like a driver issue.
    Steve
    Steve Modica
    CTO, Small Tree Communications
  • Bob Zelin
    December 21, 2012 at 10:28 pm
    Applications> AJA Utilities
    Uninstall AJA Drivers
    reboot.
    Boot up your computer, launch FCP, play your video. (there are no AJA drivers loaded now). Does it play ? Yes or no ?
    If yes – then go to https://www.aja.com
    click on support, and download the latest AJA Kona LHi drivers, and reinstall them. It will ask you to reboot. When you reboot, it may ask you to update your fimrware (which is just clicking on the “update your firmware”, and then shutting down the computer).
    SO, now that you have reloaded your AJA drivers – can you play your FCP sequence ? Yes or no ?
    If the original answer when you uninstalled your drivers was “no – it still won’t play my sequence, and is still giving me the Quicktime Error -101”, then delete your FCP preferences, and try again. If you do not know how to delete your FCP preferences, write back and I will tell you.
    Bob Zelin
