Activity Forums Adobe Premiere Pro QuickTime Effects
  • QuickTime Effects
    Posted by Phillip Graebing on January 19, 2010 at 4:32 am
    I seem to be missing the QuickTime effects from my Premiere Pro. Does it install automatically, or do I need to specify it during installation? Or can I get a plugin rather than do a reinstallation?
    Thanks.
    Terry O’brien replied 15 years, 8 months ago 3 Members · 3 Replies
  • Jeff Bonano
    January 20, 2010 at 12:32 pm
    Do you have QuickTime installed on your computer? It’s probably looking for it and it’s not there. Try going to apples website and download the latest version of quicktime.
    Jeff Bonano
    http://www.bonanoproductions.com
    “I want to have a cool quote at the bottom of my signature, just like everyone else on the cow forum!” -Jeff Bonano
  • Phillip Graebing
    January 21, 2010 at 1:12 am
    Thanks for the suggestion. Yes, I do have QuickTime installed already, and according to its updater, it is up to date. Perhaps I didn’t have it installed at the time I installed Premiere Pro? I would guess in that case, I would need to completely reinstall Premiere…
  • Terry O’brien
    January 23, 2011 at 6:44 pm
    You shouldn’t need to reinstall Premiere to get it to rebuild its registery of effects files. I am not absolutely sure that this is the right key command, but i believe that if you hold down the Enter key as Premiere is booting, it forces Premiere to build a new ini file with all of the effects registered. It may be the shift key if Enter doesn’t work, but I have done this process before with success.
    However, your problem may have nothing to do with Premiere. I am having a problem with building effects in a Quicktime project because the qtx files that Quicktime uses for its effects tracks are missing. I guess that I will need to find the qtx files and install them. Or you can buy Quicktime Pro and it should come with the full install. How Apple!
