Activity Forums Adobe Premiere Pro QuickTime Compression
  • QuickTime Compression
    Posted by Aaron Cadieux on October 29, 2009 at 5:30 pm
    Hello,
    I’m working with a friend on a project. We’re cutting on Premiere Pro 1.5. We have a 5 mintute Widescreen DV sequence. It needs to be output as a Quicktime file, and needs to be under 50MB in size. Does anyone have any suggestions on what settings to use to compress it to a 50MB or less QuickTime file with the highest-quality results? Thanks.
    -Aaron Cadieux
    Jon Barrie replied 16 years, 10 months ago 2 Members · 1 Reply
  • Jon Barrie
    October 29, 2009 at 9:57 pm
    H.264 @ 1200kbps. Not sure if 1.5 can do H.264. Then there is the frame size fps rate. What’s the output for? Web?
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
