Activity Forums Apple Final Cut Pro Legacy Quicktime Color Space
  • Quicktime Color Space
    Posted by Dan Charrington on June 22, 2010 at 9:40 pm
    I had an usual question that likely has a simple answer asked to me by a sales rep. where I work that I found myself somewhat stumped to answer.
    A client had provided us with a QT file that was rendered in the JPEG 2000 codec. The question posed was whether or not the file had been created had a YUV or an RGB color space.
    I haven’t done a lot of work with color correction and the like, but the closest thing I could offer as an answer was my assumption that JPEG 2000 was one of those codecs that didn’t support the YUV color space option.
    I wanted to maybe ask here and see if I could confirm my suspicion.
    Also, as an aside, should the issue ever come up in the future, is there is a way in Final Cut (or other likewise software) to determine the color space of a Quicktime file already created elsewhere.
    Thanks everyone.
    Dan Charrington
    Supervisor, Non-Linear Technologies
    MIJO
    635 Queen St E. Toronto, ON
    416-964-7539
    Rafael Amador replied 16 years, 3 months ago 3 Members · 7 Replies
  • 7 Replies
  • Rafael Amador
    June 23, 2010 at 2:49 am
    Hi Dan,
    In video, it doesn’t makes sense an only RGB codec.
    I had a look to Wikipedia, and there is nothing that brings to think that JPEG-2000 works in RGB.
    https://en.wikipedia.org/wiki/JPEG_2000
    rafael
    http://www.nagavideo.com
  • Walter Soyka
    June 23, 2010 at 3:09 pm
    JPEG2000 supports multiple color spaces, including YUV (specified as sRGB-YCC, with 4:2:2 or 4:4:4 chroma subsampling), XYZ, and RGB color spaces. See https://jpeg.org/public/DCINEMA-v2.pdf for more.
    I think that which color spaces are available depends on which parts of the JPEG2000 standard the encoder complies with.
    As noted in the Wikipedia article, JPEG2000 is capable of completely reversible RGB-component transformations.
    I’ve only done a little work with JPEG2000, so any clarifications or corrections are appreciated.
    Walter Soyka
  • Dan Charrington
    June 23, 2010 at 3:24 pm
    Thanks for the insight guys.
    I’m brought back to my original question now: is there a way to determine the colorspace information of a JPEG 2000 quicktime file attained from an unknown source? (Via FCP, plug-ins or other means).
    Dan Charrington
    MIJO
    416-964-7539
  • Rafael Amador
    June 23, 2010 at 3:38 pm
    [Walter Soyka] “As noted in the Wikipedia article, JPEG2000 is capable of completely reversible RGB-component transformations. “
    Hi Walter’
    This what Wikipedia writes:
    Color components transformation
    Initially, images have to be transformed from the RGB color space to another color space, leading to three components that are handled separately. There are two possible choices:
    Irreversible Color Transform (ICT) uses the well known YCBCR color space. It is called “irreversible” because it has to be implemented in floating or fix-point and causes round-off errors.
    Reversible Color Transform (RCT) uses a modified YUV color space that does not introduce quantization errors, so it is fully reversible. Proper implementation of the RCT requires that numbers are rounded as specified that cannot be expressed exactly in matrix form. The transformation is”:
    I don’t see the RGB color space.
    Cheers,
    rafael
  • Rafael Amador
    June 23, 2010 at 4:35 pm
    Not sure if there is a way to determine that unless the file contains some metadata.
    I have here a little application (VideoSpec), that have no problem telling you the color space of the XDCAM or H264. Nothing to guess with those formats; however with a Prores file its shows no info on the color space.
    Rafael
  • Walter Soyka
    June 23, 2010 at 5:12 pm
    Unfortunately, I don’t know how to answer Dan’s question; I was just trying to point out that the question is valid, because JPEG2000 supports multiple color spaces. Dan, beyond the question of color space, the question of chroma subsampling will also be valid. If the file is component, it could be 4:2:2 or 4:4:4.
    [Rafael Amador] “I don’t see the RGB color space.”
    I didn’t see it in the Wikipedia article, either — but I think the Wikipedia article is incomplete. The Wikipedia article on DCI describes JPEG2000 compression with an XYZ color space. If you look at p. 11 of the PDF I linked to earlier, (https://jpeg.org/public/DCINEMA-v2.pdf) you’ll see other color spaces mentioned. Some of the color space may only availabe in extensions of the JPEG2000 standard and not in the baseline standard.
    Walter Soyka
  • Rafael Amador
    June 23, 2010 at 5:57 pm
    Hi Walter,
    I’ve found another pdf (JPEG2000 for Digital Cinema
    by Ali Bilgin and Michael W. Marcellin. Sorry can’t copy the link)
    Talks again about XYZ. I never heard about that.
    In general i’m very lost about codecs, but tis kind of posts make me Google and some times I learn something.
    It seems that this codec still being developed and, as you point, is possible that some of his profiles can support RGB. But the truth is that what I’ve read it doesn’t let this any clear.
    Anyway, here is 1 AM. Time to close.
    Cheers,
    rafael
    PS: Russell Larson may know about this. He is mastering DCI stuff.
