Activity Forums Adobe Premiere Pro Quicktime Animation Codec Distortion
  • Eddie Lotter
    April 1, 2009 at 1:44 pm
    [Matthew Lowe] “my searches haven’t proved successful.”
    That’s strange, this was discussed only a few days ago:
    https://forums.creativecow.net/readpost/3/891151
    Cheers
    Eddie
  • Vince Becquiot
    April 2, 2009 at 4:04 pm
    I’ve seen this happen on a bunch of quicktime file coming from FCP on one of my projects. Looked great on the timeline and the export looked like yours. What I ended up doing was converting to Quicktime animation through Quicktime Pro first, then replaced those files in the timeline, problem solved.
    This seemed to be an isolated case, and I couldn’t find out what format the client actually used on the original files.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Eddie Lotter
    April 2, 2009 at 4:27 pm
    [Vince Becquiot] “I couldn’t find out what format the client actually used”
    Vince, doesn’t QT Pro provide you with that kind of info?
    It’s good to know that it worked once you converted it to a known format.
    Cheers
    Eddie
  • Matthew Lowe
    April 3, 2009 at 8:46 am
    Many thanks for all your replies and the link given. I wasn’t too sure how to describe the problem so wasn’t too confident what to search for!
    The screenshot that I posted was originally a Quicktime file using the Animation codec rendered in Cinema4D. Those are perfect quality. I really am a bit confused. I seem to have adjusted every setting with no luck. The PNG codec works fine but they don’t really give a smooth playback on the laptop we’ll be using.
    I’ve decided to just used MPEG2. Even though there’s a bit of a banding effect on the gradients (something that I also can’t seem to solve) it’s good enough.
    Thanks for your help!
