Activity › Forums › Apple Final Cut Pro Legacy › Quicktime
Quicktime
Posted by Nathan Dunlop on March 28, 2010 at 3:24 amI exported my project to quicktime and it created 3 files to make one.
Is this normal?Also, when I move the folder to a different location the movie will not play but if I move it back to the original location it plays just fine. How do I solve this problem? Any help would be appreciated. thanks.
Jeff Halpin replied 16 years, 5 months ago 4 Members · 8 Replies -
David Roth weiss
March 28, 2010 at 4:37 amThat typically means your hard drive is formatted FAT32 rather than Mac Extended, so it has a 4Gb file size limitation, so it has created a new sequential file each time the export reaches 4Gb.
Those files are bogus and should be trashed. You have to use Apple Disk Utility to reformat the drive as Mac Extended (not journaled), then export again and you will see that you have just a single Quicktime file.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
EPK Colorist – UP IN THE AIR – nominated for six academy awards
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
Rafael Amador
March 28, 2010 at 4:38 am[Nathan Dunlop] “I exported my project to quicktime and it created 3 files to make one.
Is this normal? “
No.
What kind of HD are you using?
[Nathan Dunlop] “Also, when I move the folder to a different location the movie will not play but if I move it back to the original location it plays just fin”
Are you exporting a self-contained movie/
rafael -
David Roth weiss
March 28, 2010 at 4:42 amBetter go drink some more coffee Rafael. You’ll need it to beat me to the draw buddy.
David
David Roth Weiss
Nathan Dunlop
March 28, 2010 at 5:06 amI suppose that means I’ll have to back up my drive before I do that, which will be a huge pain. That explains the problem though. Thanks.
Rafael Amador
March 28, 2010 at 5:06 amDavid,
I know that in California you have systems to slow down other people posts.
I’ve posted at 11:38:40 AM on March 28, 2010.
Which is is your posting time????
I guess than some 12 hours later:-)
rafa
BTW, I wrote you almost two months ago, and, so far,no news of you. -
Nathan Dunlop
March 28, 2010 at 5:09 amI’m pretty sure I did but now I’m questioning that. I’ll try again and see if that’s the problem.
David Roth weiss
March 28, 2010 at 5:45 pm[Rafael Amador] “I wrote you almost two months ago, and, so far,no news of you.”
Sorry!!! I just went and found your email from January 18th, and it somehow went to my Junk Mail folder. I sent you a email just now… Go take a look.
David
David Roth Weiss
Jeff Halpin
March 30, 2010 at 3:42 amhi there, how can I set my export size when some clips are wider than others? I’m using iPhone clips and some are wider than others! thanks in advance.
