Activity Forums Media 100 QuickTime 7.5.5 update (PLEASE READ)
  • QuickTime 7.5.5 update (PLEASE READ)
    Posted by Scott_f Media 100 on September 10, 2008 at 2:00 pm
    Summary
    Apple QuickTime 7.5.5 update for OS 10.5.4 causes certain codecs to no longer work.
    Products affected:
    Media 100 suite 12.x running on OS 10.5.4.
    Detail:
    With the update to QuickTime 7.5.5 the Media 100i codec and the Motion jpeg-B codec no longer work. With either codec when attempting to play a clip Media 100 will report bad video frames and may produce a black frame or picon. Further investigation is currently underway. This thread will be updated when we have more information.
    Vegar Aase replied 17 years, 12 months ago 6 Members · 9 Replies
  • 9 Replies
  • Greg Snyder
    September 10, 2008 at 8:55 pm
    This also happens under OS X 10.4.11 and V12x.
    Help!
  • Floh Peters
    September 10, 2008 at 10:19 pm
    [Greg Snyder] “Help! “
    Like reminding you not to upgrade QuickTime?
    Go to Apples QickTime Support Page and locate the QuickTime version you want to install. In your case most likely QuickTime 7.5 for Panther. Download it.
    Go to YourHardDrive->Library->Receipts and delete the Receipts for QuickTime 7.5 and 7.5.5.
    Go to Macupdate.com and search for “Pacifist”. Download it
    Use Pacifist to Install the downloaded QuickTime 7.5 installer package.
    You should be good to g.
  • Alex Wainwright
    September 12, 2008 at 10:34 pm
    Thank you Floh – sheer genius
    I just hoped that we had got past all that QT version nonsense!
    Wishful thinking or what?
    All the best
    Alex
  • Joe Ciupik
    September 17, 2008 at 2:30 am
    I do not see a Reciepts folders in my Library folder. HELP. I need a project edited tonight and installed 7.5.5. I need to go back to 7.5. HELP PLEASE!!!!!
  • Joe Ciupik
    September 17, 2008 at 3:43 am
    OK so I found the receipts folder and deleted QT’s. I tried to reinstall QT 7.5 and is says that a newer version is still on the computer. Sorry for being stupid but PLEASE HELP!!!!!!!!
  • Vegar Aase
    September 19, 2008 at 10:12 pm
    Thank you for the information!
    I have the QT 7.5.5 Problem
    But i cant find Pacifist at mack update..
    Do you know where i can find it?
    Or another way out?
    Thank you!
    Vegar Aase
  • Vegar Aase
    September 19, 2008 at 10:13 pm
    Or another way out?
    Thank you!
    Vegar Aase
  • Floh Peters
    September 20, 2008 at 9:13 am
    [Vegar Aase] “Do you know where i can find it?
    Or another way out?
    Thank you! “
    Hi Vegar,
    please read this thread, where Wick from Media 100 did a summary of the necessary steps to get back to a working system setup, including the direct download links for the software you need. And make sure that you have downloaded the correct QuickTime version for your OS, otherwise your system will not boot anymore!!!
  • Vegar Aase
    September 20, 2008 at 11:53 am
    Hi Floh!
    Back in B…
    Thank you again..
    You are my big hero: )
    vegar
    Vegar Aase
