quicktime 7.2 and FCP
this might not be the right forum but I am 100% in the dark here….
Has anyone had major problems re QT 7.2? Not playing HD and 10 bit files? showing a white screen? and on FCP this message “codec not found. you may be using a compression type without the corresponding hardware card” ” out of memory” even if you have 4.5gb?
this issue is causing me fits and costing me $$.
I have tried to install 7.1 but the system won’t let me..it says there a newer version of QT already installed even if I removed it….can someone please help?
thanks
P
