Activity Forums Blackmagic Design QuickTime 7.1 and SDI out
  • QuickTime 7.1 and SDI out
    Posted by Lars Petter ommundsen on May 16, 2006 at 5:55 pm
    Hi!
    Suddenly started having trouble getting an SDI signal out from a Decklink HD Pro PCIe card. Component works but nothing coming out of the SDI output (neither of the outputs). Tried everything but have concluded that the card must be faulty or that QT 7.1 maybe got something do to with it..I am running the latest drivers from decklink.
    Any1 experienced same kind of trouble?
    LP
    Luckchild replied 20 years, 3 months ago 4 Members · 5 Replies
  • Kristian Lam
    May 17, 2006 at 12:30 am
    We’re still testing Quicktime 7.1 and have not noticed this behaviour.
    Have you tried uninstalling and then re-installing the Blackmagic drivers again? The Quicktime installation may have done something.
    Alternatively, try deleting the Quicktime recipets in your Library folder and then reinstalling Quicktime 7.04. This will verify if you’re facing a hardware touble or something software related.
    regards
    Kristian Lam
    Blackmagic Design
  • Kristian Lam
    May 17, 2006 at 12:32 am
    Here’s the link to Quicktime 7.04;
    https://www.apple.com/support/downloads/quicktime704.html
    regards
    Kristian Lam
    Blackmagic Design
  • Mark Spencer
    May 23, 2006 at 10:16 pm
    We are having trouble being able to play QT clips captured as BlackMagic 8-bit DVOO. We get audio but just a white screen. They won’t play in FCP at all. FCP 5.0.4, QT 7.1, OS 10.4.6. I’m afraid it may be a QT 7.1 issue, can anyone confirm?
    Mark
    Mark Spencer
    Freelance Editor/Producer
    Apple-certified instructor, FCP, DVDSP and Motion
    Author, Motion Visual Quickstart Guide from Peachpit Press
    https://www.applemotion.net
  • Mark Spencer
    May 23, 2006 at 11:26 pm
    Turns out we needed to go back to the older Blackmagic codec! We were using 5.4, needed to go back to 5.1.
    Mark
    Mark Spencer
  • Luckchild
    June 1, 2006 at 9:51 pm
    Chaps,
    Did this work? – this may be the same trouble I’m having….
    https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=124&postid=861402
    Be great to know if it solved the problem.
    Cheers
    Jeff Brown
