Activity Forums Adobe After Effects Quicktime
  • Posted by Jeff Carpenter on August 23, 2009 at 6:21 pm
    I have After Effects CS3 and after some crashing issues, i narrowed the problem down to Quicktime, which I deleted and now all is well. However, when i try to import a .mov file, I get an error message that says “not a valid file type for import”. Is that because a .mov file is a quicktime file, and I don’t have it installed anymore? If so, is there a way to have quicktime installed on my system so that it does not conflict with After Effects? Thanks in advance.
    Joey Burnham replied 17 years, 1 month ago 3 Members · 3 Replies
  • Todd Kopriva
    August 24, 2009 at 4:44 am
    QuickTime is required by After Effects for some things to work—like importing and playing QuickTime files.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
  • Jeff Carpenter
    August 24, 2009 at 11:58 am
    OK…that didn’t help me…is there a way to have Quicktime on my system and not have it crash After Effects?
  • Joey Burnham
    August 24, 2009 at 4:59 pm
    Just do a fresh install of both programs and you should be fine.
