Activity Forums Apple Final Cut Pro Legacy Quicktime 10 problems
  • John Pale
    May 11, 2010 at 4:16 pm
    QuickTime X is a work in progress. The Quicktime 7 installer is included on the Snow Leopard disc and FCP users are strongly urged to install it. If you have FCS installed, your QT Pro features ate automatically enabled
  • Jean-christophe Boulay
    May 12, 2010 at 2:28 pm
    QT7 should be in your Applications/Utilities folder. You just have to “pro it” with your license code. And put it in your dock. And trash any shortcut to QuickTime X (which sounds way cooler than “10”).
    JC Boulay
    Technical Director
    Audio Z
    Montreal, Canada
    http://www.audioz.com
  • Timothy Reed
    May 12, 2010 at 2:35 pm
    To confirm:
    The retool back to QT7 will NOT affect my present QTX projects in FCP7?
    Geez, a lot of anachronisms
    Many Thanks to all who have helped!
    Tim Reed
    May 12, 2010 at 3:10 pm
    The version of the QT application you open shouldn’t have any influence on the QT ressources FCP relies on. Do not delete QTX itself, of course, that would create a mayhem. Just open QT7 instead.
    JC Boulay
    Technical Director
    Audio Z
    Montreal, Canada
