Activity Forums Adobe After Effects Quick way to make composition length match child layer?
  • Quick way to make composition length match child layer?
    Posted by John Isaacks on May 6, 2009 at 1:45 pm
    I know if you drag an asset to the new composition button it makes the new composition the same length as the asset. But if I already have a composition and I add a new video layer to it, is there a quick way to make the composition the same length as the asset?
    Kyle Hamrick replied 17 years, 4 months ago 3 Members · 4 Replies
  • John Isaacks
    May 6, 2009 at 1:58 pm
    Thanks.
  • Kyle Hamrick
    May 6, 2009 at 4:03 pm
    This obviously only works if your new clip is shorter than the timeline, but hotkeys make this mighty fast:
    Assuming your layer starts are the beginning of the comp…
    Select the layer in question.
    O (Out point of the layer)
    N (Set end of render area)
    Then, if desired, right-click in your render area and “Trim Comp to Work Area” or whatever the option is named.
    If it doesn’t start at the beginning of the comp, IBON.
    Boom. Super-fast.
    If my comp is shorter than the layer in question, I usually just open comp settings, set my comp length to some value WAY over what’s needed (rather than doing the math) and then do the above hotkey trick.
    Hope that helps!
    Kyle Hamrick
    Editor/Motion Graphics Artist
    http://www.kylehamrick.com
  • Kevin Reiner
    May 6, 2009 at 8:06 pm
    To save an extra millisecond in your day, you can follow Kyle’s advice except instead of hitting O and N, select the layer whose length you want your comp to be and hit APPLE-OPTION B. Then “Trim Comp to Work Area”. Over the course of a year, this could save you 5 mins.
    😉 Kevin
    System Setup (for a more detailed list, see my profile)
    HARDWARE
    Mac Pro 2 x 3 GHz Quad-Core Intel Xeon
    9GB Memory
    Two 16x SuperDrives
    Dual-channel 2Gb Fibre Channel PCI Express card
    Apple Cinema HD Display (23″ flat panel)
    ATI Radeon X1900 XT Graphics Card
    AJA Kona LHe SD/HD capture card
    Apple Xserve Raid 5.6TB
    SOFTWARE
    Mac OS X 10.4.11
    Final Cut Pro Studio 2
    After Effects CS3
    Photoshop CS3
    Illustrator CS3
    Boris Continuum 5
    Sapphire Plug Ins
    Roxio Toast
    Digital Anarchy Anarchist Suite
    ParticleIllusion 3.0
    Trapcode
    Zaxwerks
  • Kyle Hamrick
    May 6, 2009 at 8:15 pm
    GASP! A hotkey I didn’t know about?!
    :-O
    Kyle Hamrick
