Activity Forums Apple Final Cut Pro Quick way to add sequential Takes to Clips metadata
  • Quick way to add sequential Takes to Clips metadata
    Posted by Daniel Elder on February 9, 2015 at 10:04 pm
    So I have 100’s of clips / takes for a TV Pilot I’m editing. I’m organizing all my clips right now and its super easy and great, except for adding takes to a series of clips. So if I have scene 1 and it has 40 takes in it, is there a way to quickly add the takes if everything is in order already? Kind of like how in EXCEL you can drag the box down to create a number sequence, can you do that in FCPX?
    Daniel
    Daniel Elder
    producer
    http://www.elderpictures.com
    Daniel Elder replied 11 years, 6 months ago 2 Members · 2 Replies
  • Francois Jean
    February 10, 2015 at 1:36 am
    « Shot notes x » can insert metadata from csv ( usually from notes taken on the set)
    or simply renaming selected clips of the event via the inspector ( Apply custom name menu) could modify the name sequentially following a define rule, this however does not edit the metadata
  • Daniel Elder
    February 10, 2015 at 4:48 am
    Okay cool, I’ll try the csv route, but it was a small crew so we didn’t have anyone to take notes :-/
    Daniel
    Daniel Elder
    producer
