Activity Forums VEGAS Pro Quick way of doing a J or L audio cut with Vegas?
  • Quick way of doing a J or L audio cut with Vegas?
    Posted by Mark Stuart on February 3, 2007 at 5:25 pm
    1) Is there a temporary method of unlocking the associated audio of a video clip to allow the audio to cut before or after the edit point?
    2) Related to the above – is there a quick method of doing an audio cross fade with the video doing a cut (instead of the video cross fading too)
    Regards
    Mark
    Terje A. bergesen replied 19 years, 7 months ago 3 Members · 2 Replies
  • Gary Kleiner
    February 3, 2007 at 9:21 pm
    Turn on Ignore Event Grouping (button is on top with an open padlock), and this lets you do separate operation with video and audio.
    A quick way to put in a crossfade for either video or audio is to place the cursor at the cut and hit the / key (above numeric 8). The overlap amount is set in preferences.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Terje A. bergesen
    February 4, 2007 at 5:13 am
    Vegas has many ways of doing things, Gary knows most of them. The way I do my audio overlap/video cut cuts is to select a clip, hit ‘U’ to un-group the video and audio, and then I drag the edges of the audio to overlap as much as I want. When done, I select audio and video again and hit ‘G’ to re-group them.
    I like Gary’s way though, but there are always a ton of ways to do the same thing in Vegas. Find your favorite method 🙂
    Terje A. Bergesen
