Activity › Forums › Apple Final Cut Pro Legacy › Quick time PRO
Quick time PRO
Posted by Suzin Daly on December 11, 2008 at 11:42 pmAnyone know how to launch quicktime pro and navigate to quicktime preferences?
Suzin Daly replied 17 years, 9 months ago 2 Members · 4 Replies -
Nick Holmes
December 11, 2008 at 11:54 pmSimply launch QuickTime Player and go to the menu bar: QuickTime Player > QuickTime Preferences.
Click on the Register button if you want to enter your serial number. If you have a recent copy of Final Cut Studio, you already have QT Pro activated.Nick
Suzin Daly
December 12, 2008 at 12:39 amI was told if the text in FCP is slightly muddy (and it is). I should go into quick time pro make sure the high quality video setting is checked within Quicktime pro.
Nick Holmes
December 12, 2008 at 12:48 amIn QuickTime Player, with your file open, press command and J keys to get the Properties window. Click the entry for Video > Visual Settings. The checkbox for High Quality is at bottom right. If you want this to be always enabled, go to QuckTime Player in the menu bar then, Preferences > General. Click the checkbox for “Use high-quality video settings where available”.
Also bear in mind that FCP is showing your video at a lower resolution to better enable real-time playback.
Nick
Suzin Daly
December 12, 2008 at 5:18 pmThanks, I will give it a try see if it makes a difference. It’s not that crisp after rendering and .mov. See if it makes a difference in the .mov clip.
