Activity Forums VEGAS Pro quick question – rendering to PAL
  • quick question – rendering to PAL
    Posted by David Ambuel on June 12, 2011 at 11:57 am
    I would appreciate any helpful advice – after searching the forum I am not confident of correct settings, and won’t have any way to immediately check my results.
    I want to produce a PAL dvd, from a project originally shot in AVCHD 1920 x 1080 60i. I am thinking that the thing to do is render Main Concept MPEG2 and select the PAL widescreen video stream template. Is this correct, and, if so, I am wondering: the template default is “lower field first” (while the default project settings for 1920x1080609i have upper field first). Should I change the PAL template setting to upper field first, or just leave the defaults alone?
    Thank you!
    David Ambuel replied 15 years, 2 months ago 3 Members · 3 Replies
  • Stewart Bourke
    June 13, 2011 at 1:07 pm
    David,
    I had a similar issue recently. Vegas does an incredible job of handling all the necessary conversions automatically. Unless you have very specific reasons to (and there rarely are) leave all the options alone – let Vegas figure it out. I recently had a project where NTSC, PAL, wide-screen and standard 4:3 were mixed. Once I selected the widescreen template (as you are suggesting) I let Vegas handle all the conversions – and it did it perfectly.
    You may need to do some cropping – go into the ‘pan/crop’ on the event and select ‘match output aspect’ – then make any edits as appropriate.
    There are a couple of posts about this recently on the Vegas pro forum on the COW, and it might be worth a read as well.
    Hope this helps…
  • John Rofrano
    June 13, 2011 at 3:30 pm
    [David Ambuel] “I want to produce a PAL dvd, from a project originally shot in AVCHD 1920 x 1080 60i. I am thinking that the thing to do is render Main Concept MPEG2 and select the PAL widescreen video stream template. Is this correct”
    Use the DVD Architect PAL Widescreen template. This will produce a file that is DVD compliant. Also render your audio separately as Dolby Digital AC3. Give both files the same name (just with different extensions)
    [David Ambuel] “I am wondering: the template default is “lower field first” (while the default project settings for 1920x1080609i have upper field first). Should I change the PAL template setting to upper field first, or just leave the defaults alone?”
    Stewart is correct. Let Vegas handle it. There is no problem with the filed order being different. Vegas will happily flip them for you so that your DVD player finds the filed order it is expecting regardless of the filed order of the original camera.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • David Ambuel
    June 14, 2011 at 7:57 pm
    Thank you, Stewart and John. Your replies confirm a lesson that the forum patiently keeps trying to teach me: Vegas is smarter than I am. Now on to formulate a new newb question…..
    David
