Activity Forums Adobe After Effects Quick question, changing timing
  • Quick question, changing timing
    Posted by Matthew Chapman on January 13, 2013 at 10:18 pm
    Hi All-
    I have a few composites that were made animating and lighting PNGs in 3-D space in AE.
    I didn’t have timing from the director when I started, and now that I do I find that several of the pieces are too long (I aimed long instead of short).
    The compositions have quite a few keyframes, but I just want to speed them up. I’d prefer to just shrink the time of the compositions without doing and time re-mapping or anything like that. Is that possible?
    Most comps are 4 seconds and I want to make them 2.
    thanks!
    matt
    Matthew Chapman replied 13 years, 7 months ago 3 Members · 3 Replies
  • Angelo Lorenzo
    January 13, 2013 at 11:07 pm
    https://forums.creativecow.net/thread/202/883741 You can expand/contract keyframes.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
  • Darby Edelen
    January 14, 2013 at 4:32 am
    You can drag your long composition onto the comp button at the bottom of the project panel to create a new composition with the long comp as the only footage item, then apply time remapping and pull in the last keyframe to 2 seconds.
    Time remapping by this method in the case of keyframed animation is exactly the same as stretching the keyframes in the source (long) composition, but I find much easier.
    Is there any specific reason you didn’t want to use time remapping? It’s really the easiest way to remap keyframed animations and you lose nothing.
    Darby Edelen
  • Matthew Chapman
    January 14, 2013 at 10:19 pm
    Thanks Darby, I will use that method. I didn’t want to get any artifacting or aliasing since they are still PNG’s being animated over time with lights, etc. But it seems that will work.
    best,
    matt
