Activity Forums Adobe After Effects Quick Question about stroke effect
  • Quick Question about stroke effect
    Posted by David Bralha on August 31, 2015 at 2:04 pm
    Is there a way to add a stroke effect to only 3 of the 4 sides of an object, instead of all sides? I don’t want to mask one side out, because then I’m also loosing a part of the object.
    Thanks.
    Brian Charles replied 11 years ago 2 Members · 1 Reply
  • Brian Charles
    August 31, 2015 at 3:18 pm
    If you use 3 open path masks on the layer then apply the Stroke effect 3 times, each instance set to use one of the masks.
    The trick is in the compositing settings or what the effect refers to as “Paint Style” for the Stroke effect –  any instances subsequent to the first one should be set to “On Original Image”.
    9196_multistroke.aep.zip
